KTM 2012 450 SX-F Factory Edition
  • KTM 2012 450 SX-F Factory Edition
    Wäre auch als EXC zu mögen.
      Jo! :)
        Zitat von Martin Beitrag anzeigen
        Jo! :)
        Wie deine is keine factory??
        Pavian Parade ruled:trara:
          Sieht ja ma geil aus
            nö!
              Was is da nun anders als die Aufkleber,
              oder habt ihr so große Schrankwände das die da rein passen
                Auf den ersten Blick:
                Sitzbank: Camelbank
                schwarze Felgen
                oranges Kettenblatt
                Oranger Rahmen
                Und die Aufkleber.
                Net viel, mit großer,optischer Wirkung, IMHO:
                vs
                  die Tankspoiler sind auch anders geformt scheint mir.
                    sieht ja wirklich klasse aus die factory:gut2:
                      Ich warte auf die 2012 SixDays Germany bzw 2013:schwärm:
                          ENGINE
                          • New 449.3cc fuel-injected, single-cam, lightweight 4-stroke engine
                          • Bore/Stroke 95mm/63.4mm
                          • 5 speed transmission with hydraulic operated single spring diaphragm clutch
                          • Die cast engine cases and lightweight engine parts provide 4.4lb weight savings
                          • New Keihin 44 mm throttle body with repositioned fuel injector
                          • Newly designed single cam valve train with ultra light rocker arms, 4 titanium valves and high performance springs and retainers
                          • New piston featuring a 12.6:1 compression ratio and box in box design, with new compression ring and oil scraper ring
                          • New crankshaft with Pankl plain bearing connecting rod and minimum inertia
                          • KTM PowerParts User Setting Tool for precise fuel injection and ignition adjustments as well as data logging
                          CHASSIS
                          • New frame design powder-coated in orange
                          • Newly designed black anodized triple clamp for improved flex and handling characteristics
                          • New one-piece cast swingarm with larger diamater axel (5mm larger rear axle (25mm)) for new level of performance handling
                          • Aggressive new bodywork including front fender, number plate, radiator shrouds and airbox covers
                          • New fuel tank design with threaded inner screw cap
                          • Black Excel rims with machined hubs, black anodized Renthal Fat Bar with new KTM 827 bend
                          • Red Bull KTM Factory SX Race Team graphics and racing seat
                          • Orange Anodized Rear Sprocket
                          • Equipped with Dunlop MX51 tires
                          Info:
                          http://www.ktm.com/us/mx/450-sx-f-factory-edition-usa/highlights.html
                            toll neuer Achsdurchmesser hinten...
                              SixDays GDR edition
