Bodone Ferrari
    Mäxje, wie recht Du hast...ich find die Dinger auch einfach nur geil :schwärm:
    Von allen Dingen, die mir verloren gegangen sind, habe ich am meisten an meinem Verstand gehangen.
    Zitat: Ozzy Osbourne
      Technical Data
      • Type ....................... Motorcycle Rally Competition
      • Brand ........................... Bordone-Ferrari Motorcycle Italiana
      • Model ........................... E1 Rally
      • Engine 4 stroke ........................... TM
      • Displacement 449 cc .......................
      • Bore / stroke .............. 97 mm x 60.8 mm x 1
      • Compression ratio ...... nd
      • Power ...................... nd
      • Power .................. Keihin diam. 41 cm
      • Digital electronic ignition ........................ Keihin
      • Starting ..................... Electric
      • Multiplate clutch ..................... oil bath
      • Transmission 5-speed ...............
      • Secondary transmission Chain ..
      • Trellis frame ........................... tubular chrome molybdenum steel
      • Double Fork ........................... aluminum arms
      • Front Suspension Kayaba inverted fork ............. diam. 48 cm
      • Rear Suspension ........... kinematic progressive Donerre a shock,305 mm total stroke
      • Front brake Brembo 2-piston ...................... 300 mm
      • Rear brake Brembo 1-piston ..................... 240 mm
      • Wheels / tires 90/90-21 ........ 21 "130/80-18 18"
      • Dry weight 130 kg ........................
      • Curb weight 158 ​​kg ....
      • Total length 221 cm ..................
      • Wheelbase 1535 mm ...................
      • Seat height 996 mm ..................
      • Fuel tank capacity 32 l ..
      Schaut extrem geil aus, aber irgendwie fehlt wohl mindestens ein Scheinwerfer...:kratz:
      Life should not be a journey to the grave with the intention of arriving safely in a pretty and well preserved body,
      but rather to skid in broadside in a cloud of smoke, thoroughly used up, totally worn out, and loudly proclaiming
      "Wow! What a Ride!
      ― Hunter S. Thompson
        man man man Photoshop lasst grüßen
          gestern schon gefragt: Wo ist der Dämpfer
          Seh in jetzt auch bei den Detailbildern nicht.
            Man sieht doch das Federbein mit umlenkgebimsel
              links neben der rahmenstrebe in fast der gleichen farbe
              Pavian Parade ruled:trara:
                Die Umlenkhebel hab ich schon gesehen, aber nicht das Federbein, aber jetzt seh ichs auch.
                Gestern bei den kleinen Bildern nicht und am Nachmittag am Handy sah ichs auch net.
                  schickes Teil, aber der fette Akrawallo sieht aus wie unmotiviert drangenagelt
                    "Wow! What a Ride!
                      nun ja, die Geschmäcker sind verschieden. Die Akra wirkt wie zu Testzwecken hingebastelt. Oder hängt das Motorrad am Akra dran:kratz:? Ansonsten erinnert sie mich von der Grundform stark an die gute alte Honda Dominator. Der muss man vorne nur noch ein Horn (Schlangen- oder Alienkopf) verpassen.
                      Howard Zinn
                        Wer hat denn da für die obere Verkleidung Modell gestanden? Free Willy??? :auslach::craz:
                          Mich erinnert es eher an Alien:
                            "Wow! What a Ride!
