- Shaft drive inline 2-cyl engine - 270-degree crank
- Mass kept low and central for agile handling
- Intelligent Unified Brake System and ABS
- YCC-T with 3-stage traction control plus Yamaha D-mode
- First edition adventure pack
- Tough spoked, tubeless aluminium rims
- Adjustable front and rear suspension
- Adjustable seat height
Displacement1199 ccBore x stroke98 x 79.5 mm
Compression ratio11.0 : 1Maximum power-Maximum torque-Lubrication system
Dry sump, oil tank in crankcaseFuel System
Fuel injectionClutch typeWet, multiple-disc coil spring
Ignition systemTwin sparkStarter system
ElectricTransmission system Constant mesh, 6-speed Final transmission Shaft
Fuel tank capacity23 LOil tank capacity4.2 L
Chassis -
Chassis:Steel tube backbone
Front suspension system Telescopic forks
Front travel190 mmRear suspension systemMonoshock, adjustable preload and rebound damping
Rear travel190 mmCaster angle28°Trail125mm
Front brakeHydraulic Twin Ø 310 mm wave discs
Rear brakeHydraulic Single Ø 282 mm wave disc
Front tyre110/80R19M/C 59V
Rear tyre150/70R17M/C 69V
Dimensions -
Length2,250 mm
Width980 mm
HeightMin:1,410 mm / Max:1,440 mm
Seat heightAdjustable 845-870 mmWheel base1,540 mm
Minimum ground clearance 205 mm
Wet weight261 kg
Q:motorcycledaily.com
wieder nach hause gefahren...
