i have looked into a spare RPM Counter of a RD04 of 92.
Yours must be from 1991 cause it looks on the photo that you do not have the sidestand light in the RPM Counter inside.
Do you have a sidestand light externally ? If so the build of the RD04 is 1991.
Anyhow, the colours Robbe told you are correct as i looked inside the RPM Counter tonight.
The other component is burned too, so you should look if the connections between the components are ok.
Good luck for the rebuild. :Auge2:
