Drehzahlmesser RD04
    @RoadKill.dk
    i have looked into a spare RPM Counter of a RD04 of 92.
    Yours must be from 1991 cause it looks on the photo that you do not have the sidestand light in the RPM Counter inside.
    Do you have a sidestand light externally ? If so the build of the RD04 is 1991.
    Anyhow, the colours Robbe told you are correct as i looked inside the RPM Counter tonight.
    The other component is burned too, so you should look if the connections between the components are ok.
    Good luck for the rebuild. :Auge2:
    ich kicke mit dem Daumen....
      cry cry cry
      Hey all
      Now i tryed my tacho with the 2 new komponent, but it diddent help , its still all dead .
      Any of you know, what else could be the problem ?
      - maybe its that big black thing, IC , with 16 legs ? or maybe the CDI ?
      Christian
        Is it the tacho or the rpm counter ?
        Check the circuit path between the components. It might be that there is something blown by the heavy voltage which passed thru.
        If you need the tacho and it is really a 92 RD04 then i do have a spare one.
          Hello Bhristian,
          I've got a revmeter as well as a speedometer for sale. Suitable for RD 04, '91 model (without tripmaster).
          Cheers
          Harry
          There's no replacement for displacement
            Hey Paco
            Is the tacho and RPM counter not the same ?
            ill might bye it from you if i cant make it work
            Christian
              revmeter
              Zitat von Maverick Beitrag anzeigen
              Hello Bhristian,
              Cheers
              Harry
              What is a revmeter ? :craz:
                Zitat von RoadKill.dk Beitrag anzeigen
                Hey Paco
                Christian
                Hi Christian,
                no it is not the same.
                The rpm counter (or revmeter) does count the rpm's of the engine, the tacho does show you the kilometers per Hour (how fast you are)
                Therefore if the tacho is dead this will only influence the tripmaster as the mechanical signal from the fronttire will be changed into an electrical signal for the Tripmaster.
                If the rpmcounter (revmeter) is not showing anything it is just that you do not know the rpm's of the engine.
                Regards
                Heico
                  Hello Bhristian,
                  Cheers
                  Harry
                  Hey Harry , how mutch for your revmeter ?
                  Christian
